Recently picked up a Wards 525 frame to build a rider. There is much previous owner engineering to fix. Having never owned one before my question is, are the legs of the swing arm supposed to be parallel? The one leg is 90 degrees to the shaft, the leg with the brake lever angles away from the other nearly an inch over it's length. (greater than 90 degrees) Is this normal?
Also want to thank Roadmaster75 for posting a source for swingarm flange bushings. The search function on the site works well if you know what you're looking for, (found the bushing post) but I couldn't find an answer to my swingarm question. Thanks for any info.
