what type of header should I get?
I'm building a honda gx 200 from scratch. this is the party modification list below
honda gx 200
14cc head
copper head gasket
10.9 grade bolt and washer kit
racing spark plug
6 degree timing advance key
22 millimeter minkuni carburetor
fuel pump
carburetor adapter with pulse fitting
uni air filter
flat top piston
Billet rod and flywheel
18 pound valve springs
.265 dyno cam
stock valves and rockers
Valve case breather kit
last thing I need to order is a header. This engine I'd going on a modified Baja heat frame, very heavy. Hasn'haven't figured out which header to get cause there are so many to choose from. Any input? Thanks.
Also can anyone tell me an estimate as to how much HP you think I will be getting with this set up? I would like to have a rough idea with all of the mods, thanks guys.
