I have a stock 6.5hp clone, and I've read in the manual that the max rpm is 3600.
I bought a clutch from a swap meet awhile back and put on this thing, and noticed that the clutch is engaging late. I have to give a push on my bike so i dont burn the clutch up and then rev hard to really get the thing going.
Now I dont think theres much of a problem with a clutch engaging to early right? I mean, i know you want the clutch to engage at the sweet spot but thats not much of a worry to me. The lowest i can find is around 2000 rpm engagment
I've just been looking for the lowest engaging clutch, preferbly one that engage a little higher then idling speed because i think that would minimize wear if the clutch fully engaged at low speeds right?
I am only 15 and this is my transportation haha so I need it to be reliable and long lasting. Because I'm 15, i dont have much of a budget.
So I could you guys on here recommend me something that meets these standards?
I'm geussing I should probably go for the lowest tooth clutch right? based off of this information.
"•11 tooth clutch will give you a faster take-off and lower gearing for climbing hills
•13 tooth clutch will give you more top end speed
•12 tooth clutch is the mid-range"
I saw this one
"#35, 3/4", 12 Tooth Centrifugal Clutch"
It is on gokartsusa . c o m and I just wanted to know if that would work??
again, just give me your recommandation.
I saw this one
