Hi All,
I come to you needing help with a question I don't have an answer for.I have ridden a motorized bike pusher for about 3 years now and it's been really enjoyable.The pusher simply pushes the bike and is connected to the bike seat post.I want to change the pusher over to my cargo bike but cannot connect to the seat post as the rear cargo platform is there.Also I made up a hitch and changed the hitch bar to a vertical bar,that doesnt work due to the pushers weight and the connection being off center.In other words the bike wants to wheelie at the front and when turning I have to forcibly balance the bike.
I was thinking of adding 2 front wheels to the pusher one on each side,this way the weight of the pusher goes from my bike to the new wheels.I decided on 6" swivel wheels that have 4 ply air tires and are rated for 30 mph and 600 lbs.The hitch end is articulating and moves up and down and right/left(180 degrees) The hitch bar is stationary,just the hitch moves.
My question is in your opinion would there be any problems using the swivel wheels,I ask cause my Dad has reservations about them working.He was saying when I run over uneven terrain one of the wheels would be off the ground which could cause a problem.Also he says if I were to run into a pot hole a wheel could catch the hole and cause me to flip off the bike.His thinking this way was due to the wheels not having any suspension. He wasnt for sure on these scenarios but brought them up out of caution.
I kinda think the pusher with the swivel wheels would do just fine but too am not for sure either way.The rear wheel on the pusher is the drive wheel.
It's a bit of work to add the wheels to find out if it works so I first thought maybe one of you might know the answer.
Thanks!
Thanks!
