I picked up a beater bike the other day. Its got a Wisconsin engine on it, I think its a 4.5 horse. It has a runability issue, It fired up easy makes great power, no smoke, and super quiet. BUT its missing an air cleaner assy, it will only run with the choke almost fully closed, and the linkage assy is a mess, They literally were riding it with the throttle setup in reverse (twist the throttle to go to idle, so I am shocked the forks are still straight as a arrow :laugh
I dont even know if this is in fact the right carb for it, Its a Keihin and actually looks like a clone style carb. I did yank it off,clean it (it was actually pretty clean) and installed a missing gasket. It performs the same and may be due to no air box. The spacing is real close to the Tecumseh carb, I can get it slipped down the studs and the spacer block matches pretty good (will have to open up the stud holes a little, and it will be a tight squeeze to get the nuts on).
Just wondering if anyone has run one of these engines and done something like this. Not trying to do anything fancy other than make this a usable inexpensive bike for someone.
