Hello there, I'm not sure how much this forum focuses on old dirt bikes but I have an issue. I just recently picked up a 1990 Yamaha RT-100 two stroke, it was rebuilt with a Wiseco piston and Boyesen performance reed valves. It also has a brand new carburetor. It has an issue where it won't rev up, no matter how the mixture screws are adjusted. It will rev to about 2000-2500 rpm and then bog down and cut out, but will stay running fine- meaning it doesn't die. When I remove the air filter and screw out the pilot jet most of the way it revs up almost all the way and runs good but still not perfect. I have checked the exhaust and don't believe it's clogged because the thing ran great before the rebuild (that's what the guy I bought it from said at least).. Spark plug was not fouled, just wet. I'm thinking it's a jetting issue in the cheap carburetor, possibly needs a smaller one- but need some tips!! I don't think it's a spark problem because messing with the air intake changes the performance. Please give thoughts, Thanks, Tom.
