Z50A - K3 from 1972??
Anyone need any of the parts off this? I know everything needs a price, but I'm not sure if any of the parts are even desirable on this bike. Serial number reads Z50A-1023967
It's taking up space and I can't bring myself to scrap it.
ouch:doah:
hi how much for the flywheel cover shipped? is it broken?? or how much for the hole motor shipped to NC 28382... does it turn over??
I'm not sure if the engine turns over, it appears that the kickstarter is not tight enough on the spindle to check, it just spins on that splined shaft. I will go out in a bit and see if I can't get it tight enough to crank it. Otherwise, I'll let that flywheel cover go for shipping plus 5 dollars.
it sounds like the kick shafts splines are stripped out, they are real bad for going on these Honda 50 & 70cc bikes..
ill take the flywheel cover if its not broken..
Both wheels and forks are spoken for as well as well as the engine. The people in line for them pm'd me. So if you didn't pm, you're not one of those two. I'm out on a well site today and will get measurements and details that have been requested this evening.
