All prices do not include shipping. I will ship all the engines and bulky things UPS. I have included the unpackaged weight and you can run rate quotes yourself from zip code 83864. PM me with any questions. Thanks!
Briggs & Stratton 4HP - $50
This engine runs great and seems to be real low hours. I believe it's a ball bearing engine. Engine runs well with another carb/tank - will need carb and tank cleaned.
1973 No. 100232 0223-01 73121307
32 lbs
Shaft: long portion is around .782 diameter and 1.5" long. The flat step-down is .75 diam and .57" long. The taper goes down to about .61 and is .72 long. (measurements made by cheap micrometer)
Briggs & Stratton 5HP - $60
This one has been updated to the Magnetronic ignition coil. It has the auxilary PTO shaft and has beautiful decals. Engine runs well with another carb/tank - will need carb and tank cleaned.
1967 No. 130292 0125-01 6711217
30 lbs
Briggs & Stratton Raptor Race Engine - $150
Nice long header and air cleaner. Engine runs well with another carb/tank - will need carb and tank cleaned.
Year: 2000
32 lbs
Briggs & Stratton Raptor PARTS Engine - $60
The end of the crank is broken, a valve is missing...? For parts.
Exact same Model/Type/Code as the above engine
15 lbs
12v Electric starter - $125
I have tested it with a battery, it works great.
14 lbs
32 lbs
30 lbs
Year: 2000
32 lbs
15 lbs
14 lbs
