What kind of clutch is this?
What kind of clutch is this? NOW WITH PICS
I have a Comet clutch. the only thing it says is "Comet Clutch Richmond Indiana Pat Pend. Its a 12 tooth. Anyone know any detail on this clutch? is it older? It doesnt have a set screw! thanks in advance, the clutch is in two pieces (the outside with the sprocket on it, and the inside has the springs and shoes)
I am trying to figure out how to upload pics right now. I am just wondering why it doesnt have a set screw. How would it stay on the crankshaft without a set screw?
well if your crankshaft isn't drilled and tapped, then your screwed. Gotta either have a clutch with a set screw for un-tapped shafts or bolt in the end of the shaft with a flat and lock washer to retain the clutch.
