Well, this is more of a rant but also looking for advice on how you guys would have dealt with this situation just for my own future reference. So, I do a lot of buying/selling on Craigslist. I buy car parts, fix them up/refurbish them as a side hobby, and sell them. An opportunity raised to...
Hi I am a new to this mini bike stuff. ive posted on here already and got great advice but I failed to properly introduce myself. I recently acquired a Baja mini from a dude that baught it at tracter supply so im assuming its the mb200. anyway the thing was in pieces (a lot of pieces). but using...
Im sure some of you guys have had similar situations.
I have been dating this girl for about 15 months. She is great, her daughter is great and I love them to death.
Her ex is the problem. He is a piece of garbage. 3 months ago he stopped paying his child support. They took his driver...
eninge=honda gx390
mods ordered=
highflow airfilter
header/exhuast pipe
heavy duty valve springs
index for spark plug
gov take off-getting removed-once i have the billet arc rod.
pulse fuel system .
mods to do .
advance timing 4-6deg**
billet rod**
maybe a flat top piston for higher...
ok. so ive been working on my rupp engine for almost a year now, keeping everything original and my hopes up.
as of now my Tecumseh h35 has all the parts that it needs to run, but i lack the tools to put the rod and rings in.
so i called local shops (10 of them) AND.. 8 of them said they dont...
so i finally spent a few dollars to step the hp up on my lifan from harbor freight. this is not a cruiser bike, and it will be for racing around with my friends. i dont dare take it to the mini bike drags, i dont wanna get spanked by minidragbike!! lol.. :laugh: i dont want to be the fastest out...
I finally got A hold of more power.. I took the 5HP out of the trike to use as my first "mild" performance build that will be going in my Cat 200x
The Model:130202 Type:1819-01 Code :83020407
The gas smells real stankin old and this thing needs gone through. I wanted to do a "mild" build. I...
I've done some work to my 6.5 briggs intek, and now its acting up. can anyone give some advice? I milled and ported the head, upgraded the springs, advanced the timing, and threw a 22mm mikuni on it. But boggs out in high rpm. Am I missing something?
Thanks :confused:
ok so i have a 6.5 hp clone engine. i've removed the governor, put in the 8 deg. advance timing key, and rejetted the carb. my budget is limited and was wonder what y'all would suggest as the next step to hop up the engine some more. i'm planning on doing one mod., then save some $$$ do another...
If your wrestling with this problem heres what I did.
1. Release air from tube
2. Grab tire in vice
3. Obviously remove nuts and bolts holding wheel together
4. Apply w-d 40 or other lube to tire bead close to wheel
5. Give it 5 minutes and wiggle and pull wheel out
6. Repeat on other...
