gas
  1. Not so mini bike
    Briggs flow jet carbs and gas tank
    Red carb was on a 5hp green was on a 3hp. Engine ran with red one green one I bought and never used. $35 shipped for both and extra parts. Gas tank was on a 3hp Briggs. Super clean inside $25 shipped
  2. 125ccCrazy
    New Ding How/Universal FG gas tank
    F/G gas tank molded from an original Ding How tank, these work well on most twin upper tube style frames, great for a restore of a DH or a custom build.. $75
  3. t555trailblazer
    Cushman Trailster gas tank
    1962 cushman Trailster gas tank. It has a squared off look to it. If anybody has one or know somebody who does I would surely be interested.
  4. delray
    round gas tank
    I have one new large round gas tank. comes with a 1 3/4"vented cap. standard 1/8 pipe threads for the drain outlet. outside tank has been clean and has a light coat of primer. inside has a light coat of petroleum oil for storage protection. measurements are about 8 1/2''L x 4'' H at the edge of...
  5. M
    Do they make hinge kit for our seats to fill the gas easier?
    My old style doodlebug is a pain to fill with gas . Some one has to make a quick release or something.
  6. delray
    round gas tank
    I have one new round gas tank. comes with a 1 3/4"vented cap. standard 1/8 pipe threads for the drain outlet. outside tank has been clean and has a light coat of automotive primer. inside has a light coat of petroleum oil for storage protection. measurements are about 8"L (from edge of the...
  7. F
    what's leaking gas on my Tecumseh ?
    its not quite "mini" but I don't know where else to post - its a good size Tecumseh with series 20TAV on a vintage Cushman - I let it set too long - petcock was clogged - after getting flow, this plastic rectangular box piece seems to be leaking gas at a bad rate - what is this part called? what...
  8. delray
    round gas tank
    I have one new large round gas tank. comes with a 1 3/4"vented cap. standard 1/8 pipe threads for the drain outlet. outside tank has been clean and has a light coat of automotive primer. inside has a light coat of petroleum oil for storage protection. measurements are about 8 1/2''L x 4'' H at...
  9. delray
    round gas tank
    I have two new round gas tanks. comes with a 1 3/4"vented cap. standard 1/8 pipe threads for the drain outlet. outside tank has been clean and has a light coat of automotive primer. inside has a light coat of petroleum oil for storage protection. measurements are about 8"L (from edge of the...
  10. Danny01
    Oil smells like gas
    I went to check me oil, still at the threads, and wiped some on my finger, and I smelled it, it had a slight smell of gas. Is that because these small engines store the oil right under the piston? Or because when I shut it off gas is in the cylinder and goes down in the oil? Don't think it's...
  11. apekillman
    gas cap advice needed.....
    so i bought an aluminum tank and mounting brackets for a predator. the rear mounting bracket is a poor design, i feel. get in the way of the throttle linkage mount. anyway, the cap came with no gasket. i didn't even really think about it until i couldn't figure out why gas was leaking...
  12. MINI-MATIC
    FS Briggs Gas Tank
    For Sale,I have a Briggs Gas tank.It is dent free and would be a great candidate for a restore,not all rusted,in great shape.Came off a 80212 3hp. $20.00 PLUS $12.00 to ship.Paypal gift option or local pickup welcome.
  13. myjunk
    I am still looking for a Ruppster gas tank
    Yes, I am still looking to find a Ruppster gas tank. I am hoping someone may know where I could locate one. I know that about the time I go ahead and fabricate one, that's when one will show up! Also looking for a couple other parts for my Ruppster, if someone has any spare parts. Thanks
  14. J
    Trail Hose gas tank infomatiom.
    Dose anyone have a dimensions of the Trail Horse GTO gas tank size. Also any photos of the set up is much appreciated. I want to set it up close to the original deal. Thank you, Joe
  15. ogygopsis
    WTB: Briggs Gas Tank
    I'm looking for a gas tank for one of my 80202 model (3hp) Briggs motor. I would like the larger 3 Qt. size whose dimensions are 8.25" x 5.50" x 5.00". A little rust is OK but I don't want anything with dents. PM me if you've got one you're looking to sell. Thanks, Ogy
  16. Midyrman
    Bonanza Round Cylinder Gas Tank
    Looking for an original Bonanza under-seat mount tank. Hoping to get lucky like Alf. Thanks. Tom
  17. delray
    round gas tank
    I have one new round gas tank. comes with a 1 3/4"vented cap. standard 1/8 pipe threads for the drain outlet. outside tank has been clean and has a light coat of automotive primer. inside has a light coat of petroleum oil for storage protection. measurements are about 8'L x 3 1/2'' H . $37...
  18. R
    Pred 212 gas tank swap
    Ive got a used round gas tank on the way, I dont think i need a fuel pump as long as the tank is mounted above the carb for a gravity fed fuel system, right? What would the advantage of running a fuel pump? more options to mount the tank? I have read that people just plug up the breather on the...
  19. delray
    round gas tank
    I have two new round gas tanks for sale. they come with a 1 3/4"vented cap. standard 1/8 pipe threads for the drain outlet. outside tank has been clean and has a light coat of automotive primer. inside has a light coat of petroleum oil for storage protection. measurements are about 8'L x 3 1/2''...
