help!!!
  1. HueyLewis
    RUPP Roadster/ enduro HELP!!!
    Can anyone tell me if there is a fork that I can use to replace the damaged fork on my rupp? is there an easier to obtain fork like a dirt bike fork, that would fit?
  2. ole4
    Fox front fork HELP!!!
    Trying to disassemble a fox street scamp front fork. I saw OGY's posting from a while back but my forks only have a hole below the fender mount and looking thru the hole is the bushing. There is no higher hole and turning the fork leg the bushing behind the hole just stays there, so there is no...
  3. David wulf
    Help!!! Trying to drill a big hole
    Well like it says i'am trying to get 1 3/8 " holes in a powell swingarm . The stock arm is 1 1/2 " X 1/4" flat stock . I have welded steel to it to make it wider to handle the bigger hole . I have tried to 1 3/8 stepped bits , once i get to the 1 1/4 size the bit stops cutting . On the other...
  4. Q
    Some Log Splitter Help!!!
    So I'm upgrading my log splitter from what was a HM80 Tecumseh (Apparently 8hp???) to a GX390 (Honda 13hp), and I'm wondering if I need to upgrade my hydraulic motor, or will it be fine? :confused: I know for a fact that I have to get/make a bracket for it on the engine :shrug:
  5. R
    At a loss, please help!!!
    I have a 3hp Briggs carb (in a go kart) that I rebuilt with a Briggs rebuild kit. It ran great under load for at least 15 minutes and now it won't run! It will run for a little on choke cleaner, but then dies. Before the carb rebuild I cleaned the tank, replaced the two lines that hang down...
  6. Wagdad
    Help!!! Need different carb for my Briggs 5
    I am looking for an intake and carb for my stock 5 hp Briggs. The stock setup with carb mounted on top of tank will not fit into my mini frame! Anyone have the set up I need or steer me to one??? Thanks My set up now.....tank and carb hit the frame.
  7. 9
    Please help!!!
    Ok guys. So I got this from a friend of mine to redo for my daughters up coming birthday. I am trying very hard to find out what it is. The only thing I know is that it has a 2 cycle engine and is styled after a cruiser style motorcycle. Has plastic fenders and gas tank. and on the frame up near...
  8. S
    Tecumseh H50 racing at high RPM need help!!!
    Hi, I am trying to get an H50 running properly. I rebuilt the carb, installed new points, new plug, new gas valve, filter, etc. Put the engine back on the frame w/clutch (under load) and started her up. She starts to run like a bat-out-of-hell down the driveway, I have to hold her back or she...
  9. W
    I have a few questions that I need answered. Please help!!
    First, what is the difference between the baja warrior and the mb200 in terms of speed, which one (or both) comes with/without torque converter, and accelerating power? Second, does the baja warrior come with a torque converter already on it, because the picture I see on the Tractor Supply...
  10. D
    Rupp Swingarm Help!!!
    I am trying to remove the bushing that is inside the swingarm tube. Before I hurt myself or the part, does anyone have any ideas? It is a '68 Rupp and has front and rear brakes.
  11. arrowslinger08
    Foot Peg Placement Help!!!
    I need some ideas on how I can attack foot pegs on my Cheeftah frame to where they are lower than where the peg tube is on the frame so it gives me more knee room around the handle bars. I have a couple ideas but I want to see what some of you think I might could do. The problem I think I'm...
  12. L
    shock help!!!
    How do I take apart shocks that were on a bird duck or golden pinto. I want to completely take them apart to clean and repaint
  13. Teep
    8HP Briggs Carb/Jet help!!!
    have an 8hp briggs engine with the stock carb. i took off the air filter and made a custom header exhaust, and its not running right. when i give it full throttle, it just wants to die. if i roll into the throttle really slowly, the motor will catch up and start to rev out. this is sounding...
  14. M
    Help!!!
    I found this bike in an old shed at my parents house. I would like to restore it but have no clue what it is. If anybody has an idea I would greatly appreciate it. Also I would like to know a round about year model if that's possible. Thanks! <a...
  15. A
    Engine help!!!
    Hi I'm trying to find an engine that will fit the K&S DELLUXE SHORT TAIL. I tried to put in 2 different engines but did not fit a 6.5 clone and Briggs 5hp TOO tight of a space..any ideas would be great I really would like to know the engine NAME OR SIZE that are on the OldMiniBikes PHOTOS under K&S...
  16. T
    Help!!!
    I bought a 6.5 honda clone and today it was acting weird it used to have take off it no longer does and also ive realized that its way slower any one know what it could be??? Thanks
  17. Clayon
    Baja heat owners! Help!!!
    Any one own a baja heat with the 6.5hp? How fast does yours go stock? I wanna know so I can tell if my bike is under performing. :shrug:
  18. JackMcD
    Chain, Sprocket Issues... Help!!!
    I cannot keep my chain from popping off!!! Getting pissed!!! I’m running the Azusa 4.5” drum brake on 5” Azusalite wheel. This must be it. My sprocket alignment is perfect, my chain tension is right on. Everything spins smooth, no wobble, binding or funny noises. Put the bike on blocks...
  19. JackMcD
    Dip Stick Help!!!
    I have a nice Tec. 5hp engine (HSSK50-67338P) that I won off ebay for $50. I plan to install it on one of my frames. Upon fit-up, I had one issue... the dip stick is the tall style that interferes with the upper frame. (clears but, no way to pull the stick & check the oil once mounted)...
  20. danny n
    6.5 honda motor cam upgrade help!!!
    I need help with the 6.5 honda motor i am making some modifications to, what i have bought so far from OldMiniBikes is the super x cam, flat top piston, 0.010 over rod, 18 lb. springs, 8 degree key, all witch i dont have a problem with, my concern is that if i buy the 1.3:1 rocker arm is there...
