help!
  1. M
    1960's Briggs Throttle Issues
    Fixed!
  2. Rapidrob
    Hilltopper owners please help!
    I need a photo of the bracket the holds the rear drum brake cable to the brake. The pencil is pointing to what is broken. Would you please post a clear photo of what the bracket looks like? I will need to make one from scratch. Thank you. Rob
  3. N
    Trail Buck need help!
    Hello fellows.. I am new.. But excited.. I bought a rupp roadster 2, and now i bought a trail buck.. Trail buck is not running and has the wrong motor on it (briggs 5hp) with an adapter and a tec type bowl carb... I guess what i need help with is some pics in and around motor.. Rear and...
  4. M
    Bigger tires on Doodlebug?? Please help!
    I recently put a new Harbor Freight 6.5 engine on my Baja Doodlebug and it is amazing!! Problem? I live on a dirt road and the rear wheel bogs down into the sand. I was wondering if it would be possible to put new and bigger tires on the bike instead of the regular 145/70-6 tires that are on...
  5. Clayon
    Honda Trail CT70 Key Issues. Help!
    Well, I am fixing up my friend's Honda Trail CT70 for him. When he brought it to me the key was bent flat against the side of the bike, so I had to bend it a bit so I could turn it into the on position. Sure as hell, after moving it there the damn thing broke :censure: :doah: :mad2: I managed...
  6. P
    2.5hp briggs help!
    I'm new to forums in general so if I'm asking stupid questions I could have found answers to in old posts I apologize for annoying everyone. Okay here she goes, I own a 2.5 hp Briggs motor that sounds as if it's pounding a loose connecting rod on the crank which from my understanding is a...
  7. B
    rupp throttle linkage help!
    i got this from someone to fix and i need help. its a rupp with a briggs, i dont know anything else. the numbers on the engine are 100202 401069 6211151 it runs on choke with the adjustments very rich. i assume this is an air leak. assuming i can fix that with new gaskets, i just need a...
  8. ogygopsis
    Need Computer Help!
    Is there a way for me to prohibit one particular website from having access to my computer. I'm using Norton 360 v6 and I would like to be able to configure my firewall so that it won't let a website like Click be able to communicate with my computer. Any ideas? Ogy
  9. H
    need help indetifying name of a part
    hey guys I am brand new to the mini-bike experience. I just bought my first yesterday, it is a nice harley style eventually ill put pictures up in the what is it section see if you guys can help me figure it out (its pouring rain out today tho so its currently tucked away in the back seat of my...
  10. C
    Engine Break in on LB50? Help!
    Hey guys! So I am freakishly close to completion of my Yamaha Chappy rebuild project. Everything has been painted and its looking sharp. Now for the fun stuff.. I ordered this kit from treatland.tv for the chappy...
  11. R
    Resto Nearly finished... 1st ride today! Thank for help!
    Hi Guys, Took my first ride on my restored Fox mini bike! Great feeling! My first restoration. Predator 212cc engine runs good. I'm surprised at how quiet it is compared to my Murray riding lawn mower. I had the throttle screw in half way, guess I got to about 20 MPH. Can't wait for break in...
  12. -=deVille=-
    need help!
    i have this rear wheel sprocket that requires a very large tooth chain , i have the chain also but i was wondering who i can tell what size front sprocket i would need? and if they even make em that big. the way it was set up before it had a 2 speed gearbox on it that the motor ran a belt to the...
  13. rdog348
    Tecumseh Powersport Help!
    So my buddy gave me two of these fairly unused engines, but they have been sitting outside for quite awhile. So I cleaned both of them up nice and un-gummed the carburetors, and realized I couldn't use one of the carburetors, because it was completely rusted through. So I put the best one back...
  14. Clayon
    I can't break the bead on this tire! Help!
    I was digging through one of the out building on our farm and came across this wheel with a nice old good year tire on it. I thought it would be great for a mini bike, so I deflated the tire and tried to break the bead so I can paint the 2 piece rim, only problem is I can't! :doah: I even tried...
  15. C
    Won't stay running please help!!!
    So i bought a mini bike a few days ago. It has a Tecumseh engine on it and for some reason i cannot get it to stay running. It starts on 1 pull but dies out a few seconds later. I tried giving it some gas in that few seconds that it stays running and there was absolutely no responce from it at...
  16. frame
    frame
    need engine to go with frame
  17. T
    212cc Predator motor help!
    Hey guys, Im new to the forum. Picked up a used Doodlebug in good condition and I recently took a gamble on a Used Predator motor off ebay from a company called Tadd Wholesale. They sell Returns and stuff, so I figured I could get lucky with one that works or any easy fix. Yesterday I started...
  18. cxbra
    5.5clone engine help!
    Hey guys. I picked up a old Baja Hawg-ty with jackshaft and 5.5hp Jiandong JF168 engine. The thing is on its own it sounds like it wants to start but wont. I put gas in the carb and it roars to about 3000rpm and then dies. I think its a fuel issue. The bike was sitting for months to a year...
  19. W
    Frame Repair - Welding/Metallurgy Help!
    I recently had new jackshaft/swingarm plates welded on my Bonanza frame. I used a threaded rod & nuts to keep everything parallel: http://www.oldminibikes.com/forum/project-logs/51639-project-bare-bones-bonanza.html Problem: Unfortunately, Even though the spacing of the plates is parallel...
  20. T
    Gilson mini bike owners I need your help!
    I'm trying to restore a 5 hp one and need a few pictures of an orginal one to help us out. Need picture showing rear wheel-brake band and cable. As ours is missing and so far all I find are bands with round ends, none that bolt on one end as shown in manual. Also if you can take or have a...
