So what is the most HP anyone has gotten out of a Predator 212? Let hear some numbers of what you have done. And what fuel was it run on and what you put it on to use it? I know we have so builders on here lets hear what you have done. We can get to what parts were used later on. Thanks!
I searched and seemed to get varied opinions. Since I have a gx160 with a spare cylinder head I though might as well throw one on the predator. Is this head an upgrade for the Hemi predators? Does this head fit the same way on the Hemis as it does the older style non-Hemis? Appreciate the help guys.
I am thinking of doing a transplant on my minibike because my stock engine requires a full rebuild.
I looked at my local Harbor Freight and they have the predator 212 on sale for $119
I then searched the interweb to see what goodies are available, and all the honda clone parts say for the...
Any one ever tore apart one of these and installed a predator or regular horizontal shaft engine?
It has a pretty nice long wheel base at 41" from axle to axle and 10" rims. Can't decide if I should just use this thing for some parts, sell off parts, sell as is or take out the engine and...
NEW 6.5HP GAS ENGINE GO KART LOG SPLITTER MINI BIKE CARROLL STREAM MOTOR CO. | eBay
Looks very similar, and yet different.. Your thoughts? Price is reasonable.
:shrug:
I just saw the "jackshaft vs. 6.5 engine" thread and now I'm wondering if I did the wrong thing.
I just picked up a 212 Predator to replace the 2.5 Greyhound on the Sensation. The mini's gears are 12/60 and it has no almost no pickup or ability to get up a grade without a running start.
I...
Is there any interest out there for those with HF Predator engines?
I strongly believe that Chris's header/muffler pipe for the original HF ("Greyhound") clone was the best looking, best sounding, and best performing ever built.:thumbsup: We tried a few different "other" ones (with mixed...
Hello all.
I picked up a new 212cc Predator engine recently to run in an old mini-bike of mine.
I loosened the throttle arm nut, and hooked up a throttle, but I can't seem to get the dumb thing to idle.
The engine engages the clutch even when idling, and it idles quite high. I can't...
What is the stock jet size?
What size do I drill it to for after market hi-flow airfiter/header combo?
Same as the old blue HF clones?
I assume the idle jet will need to be drilled as well...What size?
Thanks!!
Is an adaptor mounting plate required to mount a new HF predator motor to a mini bike that has a 5hp briggs on it now? Just looking at options for when i build my 5hp so that i can still ride.
Thanks again!
