I'm freshening up a 3HP and was needing to know if what was stated in another thread I read a while back about the 5hp engine ,can you use two of the heavier exhaust spring on the 3hp to prevent the valves from floating at high RPM's?? I realize its harder on the valve train and cam, but would this be a waste of time? And could this cause any other damage other than faster wear and flywheel or rod detonation? Thanks for your input. Mark:thumbsup:
