If you cant find a used one Azusa will sell you just half a wheel....what it sounds like is a 5" live axle wheel for a go kart the outer half is stepped down to 3/4" the inner half is 1" with a key way......check the Azusa catalog pg 4 the outer part # is 8052 the inner is #8054 the only draw back the outer wheel will have a tire pressure stamp on it which you can trim off on a lathe.......Azusa Engineering, Inc. Web Site - Home Page or (626) 967 4167 if all else fails call clint at gokart galaxy hes an azusa dealer
i believe it may be! if i am reading your tape measure correct that is a 5 inch wheel, and appears to indeed be the outer half. looks to even be the same condition! even in same grey dull shape as mine! haha. what do you need for that?
