Should I use a billet connecting rod or just use the original?
Should an aluminum flywheel be used?
Does any one know of a carb mount adapter that will help mount the carb upright?
Do they sell 1" shaft centrifical clutches?
I drilled 4 holes in bottom of crankcase, I will put aluminum spacers inbetween the holes and mount metal braCKETS to bottom of engine, then mount frame to the brackets, but I need to use good rubber washers on the inside where the bolts will be, anyone know of heat/oil/gas proof rubber washers I can use?
Thanks for the help.
Hope this info can be useful for others also.
Don
Don
