any good advice/ideas baja mb200
i have a gx200 clone motor i stripped it dow and i bought,dyno265 cam,a 15.9mm carb with 38. jet and gx 140 emulsion tube,flat top piston,arc billet flywheel ,mikuni black fuel pump,26lb springs,rlv 2 stage header,and a 8 degree timing key..what should i do to gain more hp/also how much hp should i have now,and what precautions to look out for when reassembling the motor... thanks in advance..and i am also running a straight chain thinking about promod jack shaft
joekd
Advice
1: making multiple posts saying the exact same thing is not a faster way to get an answer
2: no way to know exactly what amount of power you are making
3: did you change the gearing? If not it's going to really suck running straight chain. The jackshaft or a TAV is a much needed upgrade
Welcome to the site
fonz
New Member
This is a classic:
Who's on first
What's on second
Who gives a spit on third..
pass the xanax..and a red hot...
