Looking for some electric hot water heater help.
The problem started Monday morning -luke warm water. (tank is aprox. 15 years old) two element 5500 wqtt 240 V.
I figured it was an element (reset was not tripped) so Monday evening I shut the breaker off and drained the tank, got two universal replacement elements(5500w/240v). They were shorter than the ones that came out but supposedly a suitable replacement. installed them hooked the wires back up ,filled the tank and bled the air, once water came out of all the HW faucets I turned the breaker back on. Two hours later still cold water. Tuesday second option replaced Both thermostat's with replacement thermostats. Turned the breaker back on and 2 1/2 hr's later still ice cold water. Assuming the shorter elements may have been the wrong ones(even though the watt's were the same) and burned out. A different store had Reehm brand elements in the 5500W 240v longer element. So I returned the two shorter ones and the thermostats (thinking they were inferior to the Reehm brand) and got two new elements and thermostats. Installed them and 2hr's later ....cold water. I cleaned all the grounds and checked all the terminals every thing was tight . The twelve /two with ground connects white to the red on the tank, black to the black and the ground screwed to the tank. I cleaned those connections and new wire nuts . It's like there is no powers so I checked . I put the leads on the top two screws of the top thermostat and I get 0 When I put one lead on one screw and the other lead on the tank I get 120 (both screws). same thing on the elements. So I'm getting both legs of the 120 (one on each side of the thermostats) but not the 240 coming in
I'm assuming without 240 to the thermostat the elements aren't even coming on. I've been at this for 3 days what am I missing? Is the problem in the breaker box? I'm thinking it has to be, all the electronic hardware for the tank is new as of today
any help is appreciated.
