IMO they're not that great of a plug. The only reason I see to use them is in karting where you're racing in a restricted class. The plug takes up ever so much more volume in the chamber and allows you to get a slightly higher compression ratio. But on a mini bike or anything where you're not restricted I just like a single electrode plug. Ngk bp6es is a good plug, same heat range just with no resistor in the plug.
