I just got this bike Monday and I already had to tear it down and fix it up.
When I got it the original tec was on it but did not run. The mag coil came loose from the steel core and the flywheel ate it. Also the Carb was missing.
The previous owner gave me a brand new in the box predator 212 and it wasn't long before that got installed.
The engine fit right on with no redrilling of the engine plate.
After a couple times of riding it I realized that a scrub brake is really hard to use if you are 6' 4", and that the 212 was really close to the rear tire. I then started tearing it down, I cut off the scrub brake and cut out the engine plate. I moved the engine plate forward lane re-welded it. I needed better brakes so I ordered a mechanical brake caliper and made a mount for it. Here is the bike at the moment; I still need to permanently weld the caliper bracket on and make a cable bracket.
My next plans are to install a spring chain tensioner, fold up foot pegs midway back, fit 15" tall tires, and strip/paint frame orange.
The engine remains stock for now but a header/filter are in the works. Billet rod/flywheel come next, then the gx160 head. Probably fit a mikuni later on too.
I'm building this bike to take to car shows, drag races, and other motorsport events for transportation and entertainment.
