Baja Minibike
I recently bought a Baja minibike that was left outside for an entire winter but I got it for a great price. I got it home decided that I was going to fix it up and make it drivable again. I took out the sparkplug and it was perfect, so I flipped it over and pulled it 40-50 times to drain the water out of it. It seemed that all the water was out. I put in new gas, and new oil. I tried to start it and it wouldn't start so I primed the head by pouring gas into the spark plug hole and it started for 5-10 seconds and then shut off, and does this every time that I prime the head. What would be wrong? Could it be water in the carb?
EDIT: Its a 196cc and I'm assuming it has 6.5 HP
MB165
yes pull the bowl off the bottom of the carb. more than likely theres gonna be water in there. Hopefully it isnt all corroded up. yes the 196 is 6.5hp.
incogrhino
Like said... drop both bowls. Spray out good.
I tried to go for a quick run today.... my rear shoe stuck to the drum. Liner seperated after I took it apart.:doah: dug in the stash.....:thumbsup: good to go... try again tomorrow..:laugh:
