modified the exhaust some.. cut the tip off at an angle, flipped it around, and then welded it back on to direct the exhaust up some.. plan to make it a flame thrower exhaust.. as soon as i find a damn nut that will fit a spark plug. ut:
AND.. that would be the new engine.. Lifan clone..just a tad bit different than the honda clone with the side cover shape. Its suppose to be a bit higher compression.
BTW..the NRracing choke hold clamp seems to have been made by someone who put no:censure: thought into it.. when you put it on like its suppose to be.. it jams between the air filter adapter and the carb.. so there is a HUGE air gap rendering the air filter useless.... so.. a rubber band will do again on this one.
