Got another DB30 today to keep the first one (green bike) relatively stock for the boys as a learning tool. The green bike has a pretty good running engine, and I'll keep the other engine as a spare. Also picked up a 6.5 HP motor at Harbor Freight today, and ordered a max torque clutch for the heavily modded bike (red bike).
Would a better clutch for the red bike be the best inexpensive mod, like a max torque? I'm trying to figure out what the weakest performance link is. Sprockets, clutch, or gear teeth on the clutch (I've seen up to 18 teeth for the front gear, for a 50% change in gear ratio)?
Also, would it make any sense to fit a TAV2 to a stock (green) bike?
Being 195 lbs, I'm trying to figure a way to make it so I can ride both, because as it is now, I'll only be able to play on the red bike.
Thanks!
Thanks!
