Need a little advice fellas. Finally completed construction on my sandblasting cabinet and got
everything up and running. For the past week or so I've been experimenting with various
sizes of glass beads and other media. Just plain glass beads resulted in a nice finish but the
rate of progress was painfully slow. After 5 different types of media I have narrowed my
choices down to an "Aluminum Oxide and Glass Bead Mix" or crushed glass. The crushed
glass does a great job of rust and scale removal and the rate of cut is good. The final
texture has a frosty appearance and a definite peened surface. The mix cuts slower and the
final texture is smoother. I'm leaning toward the crushed glass but thought I'd check if any
of you have any thoughts or recommendations before I begin blasting in earnest. By the way;
I'm using a siphon feed system. Tnx. Ogy.
