If it's an older motor you may have a condition known as blow-by, this is where the rings are worn and the, or some of the compression, is blown by the rings, causing pressure in the crank case, which in turn blows the oil out of the crancase and causes it to come out the tube, it would show up as the load gets heavier.
there are 2 things you can do- 1 hone the cylendar and install new rings, costly if you don't know how to do it yourself,, 2 take that junk Tec, and put it on a shelf, install a new Harbor Freight 6.5 clone, may cost you $100.00, plus a new clutch, but it will be a new motor, and plenty of power to pull your butt around!!!
dave
