I am disassembling the frame and removed the jackshaft. Are these shafts still around? One of the gears is seized on the shaft and the shaft itself is a wee bit deformed. It's not bad and I'm sure it will come off, but was wondering if there is an OEM replacement available. Also, while I am convinced that the engine is original, it's not the one specified in the brochures. It's an H25 (1968 I believe), so I would like to find an H30 short block with period correct plate with or without housing; separate or together I suppose. Also, what's the best way to remove the lower fork and springs? From what I gather, nuts and bolts seem to be original except for a hose clamp used instead of a snap ring on one end of the jackshaft.
Thanks Bonanza guys!
