Ok, I disconnected the big spring that was linking the governor and the static throttle lever. Now the carb throttle seems to move as it should and I see where I should attach the throttle cable.
Now for the other problem, with it only running barely at full choke, then speeding up ful throttle as I ease the choke in. I just triple che ked the tightness of the carb to block screws and removed them and replaced the gasket with a brand new one. Tightened down very well. I also tightened down the carb to tank screws, and a new gasket is there too. Same problem. I have to unscrew the mix screw about 2.75 turns to get it to barely run with the choke off, and it runs hard, not as it should. Obviously the carb is running lean, but why? Brand new carb. Any help is appreciated, I am trying to get this thing running for my son before the weather turns.
