I am trying to locate a complete brake handle assembly (left side) that will fit 1-inch O.D. handle bars. I have done a bit of searching online at the mini bike parts suppliers and only have find 7/8-inch assemblies.
I get mine from cycle gear for $6.99 complete,then just open them up to 1" or change the end of the bars to 7/8" then every thing cost less and the selection is endless
The one at Azusa states it fits 7/8" bars. I should done a bit of research before building the bars.
The mini I started with included a new throttle for a 1" bar. I assumed that brake lever was also available if the throttle was. Not so. I think i will check out the local motorcycle parts yard and if I have no luck then I will order the assembly from smartkartparts.com.
are you looking for anything special in one or it fits and works? i think i may have something that would work . ill look in the back shop tomorrow and see if i have any thing that will work on a 1 inch bar .
Harley Davidson has 1" bars. Any place that sells chopper parts should have clutch and brake levers and cables. For a left side lever,you need a clutch lever.
I ordered the one from smartkartparts because it came with all the parts I needed (cable, ends, lever, and clips). After it arrives I will post on how it fits the 1" bar.
