That's a Vacu-jet carb. There's no diaphragm. You can tell the difference by the choke handle. The Vacu-jet has a horizontal handle, the Pulsa-jet has a vertical handle, and has a diaphragm.
So, drop the tank and make sure the pick up tube is clear, and remove the mixture screw and with aerosol carb cleaner, make sure that is clear as well. Initial setting for this screw is 1.5 turns out(gently tighten all the way in, back it out 1.5 turns). With the engine running at approximately 3000 rpm, turn the screw in until the engine looses speed. Then turn the screw out until it begins to run unevenly. This may seem too rich, but should perform well under load.
