Hi guys,
I'm new here but have used this forum as a resouce for the past year.
I bought a Coleman Bt200x b last year, and it has run smoothly, with only minor issues.
About a month and a half ago, my clutch tension bolt came loose, and I was foolish enough to not to replace it.( I just screwed it back in with threadlock and a tension washer) Within a week, the bolt came loose and I lost it. Before I had even found out, the clutch drifted out and the torque snapped my crankshaft. What a pain.
I spent $90 for a new tension washer, bolt, and crankshaft from Coleman. I swapped it out. Every piece that came out went back in, cleaned to perfection.
I tried to start it, with no luck. Since then, I have cracked the engine open again, tested the fuel, fuel lines, carb and all the wiring. The kill switch works fine. I have used starting fluid, and put a little fuel it the cylinder through the spark plug hole. I swapped out the sparkplug. I dont want to take it to a shop, but will as a last resort.
Please help! Thanks...
