When the spring was pinched and you started it, did you have the chain off or the back tire off the ground? What should happen is you start it choked, and just as you open the choke the RPM goes up applying the clutch and the bike should take off violently. This happens because the governor cannot move the throttle to the idle position with the spring pinched.
