Bullfrog Hemi Predator High Compression Piston
fhpe77
Now you guys are just breaking my balls. If I was bent on copying the design I would simply purchase one an measure it. As far as I'm concerned this is a dead issue. I'm sticking with the stock flat top piston and having the head milled. It's cheaper and it should perform better due to better flame travel.
noseoil
Flame travel is the speed the flame moves after the "charge" in the combustion chamber is ignited by the plug to burn the fuel. There are a lot of factors affecting this speed, but it's been a subject for power (efficiency) with mods, head design, combustion chamber shaping & a bunch of other things. Basically, the faster the flame front, the more complete the burn & the more power is extracted from the air-fuel charge.
Here's a link to a good example of how this stuff gets used. Good luck!
tumble and swirl, quench & squish | Grumpys Performance Garage
I built this last year cause at the time nobody was making domed pistons and I had to cut my Wiseco down anyways for the long rod. This thing rips. .110 dome. Stock chamber. No clearance issues with my .330 Cam...
#27
I just don't want to run ally. I don't like the corrosive properties. Gas is more reliable. If I have to I'll run Sunnoco GTX 104 before I run alky. The reason I want to run a dome piston is to get to 11:1 without milling. Because I know nothing about valve train clearances and geometry when it comes to milling a Hemi head
I'm going to run higher compression and stay on gasoline so don't worry about 11:1. Just make a pass on a new plug and kill it WOT. Read the plug for fuel and where the timing mark is.
