Timing
Well my eBay timing light arrived. Hooked it up and spun the motor with a cordless drill.....nothing. Dead. Ugh. So I bought another one through Craigslist. Guy demonstrated that it worked on his car. (my car is a Subaru with no access to the plug wires). Anyway get it home and no dice. Light would not strobe. Hmm... Then I replaced stock flywheel with the ARC wheel thinking it might have hotter spark. Nope. Then I hooked up my spark plug gap tester and tried grounding the lead. Nope. Set it for max opening that spark could jump. Nope. Then started dialing it back, and what do ya know? A gap of about .25" is just right for the timing light to pick up....OK, back in action.
I found TDC with a dial gage directly on the piston center (head is still off), and set a timing wheel to TDC using a piece of wire for the indicator. Then checked where on the rotation the flywheel was when it sparked. 33°BTDC for the ARC wheel when using the key. These pics are with the motor cranking at around 1200rpm, and are actual timing light reads.
I measured the stock flywheel timing as 25°BTDC.
Wanting more low end power, and not in need of over 6k rpm, I set it to 28°BTDC without a key. Took a few tries while tightening the nut to get it just right...
So then I needed a way to torque the flywheel nut. Here is my locking bar.
Just some mild steel with a 3/4" hole drilled in and some welded tabs. Works great. No marks left on shaft.
OK, still have to finish carb adaptor and header then we can fire this puppy up and see what we get....hopefully not a broken case! To that end, my mud motor does not direct drive the shaft with the housing attached to the motor. The motor is mounted to a frame and is coupled to the prop shaft with a CV joint (from a Polaris ATV) so the long shaft should not stress the motor casing (much).
