I appreciate the detailed explanation about the crankshaft revisions marcus. Based on the serial number of my HS50: 5099B, shown in the second photo, my understanding is this engine was built on 4/10/1975. I will look for a TEC 34740 crankshaft. And Sixpac440... I will keep the lathe option open. Thanks again! - Joe
Yes you are correct, it is a 1975 engine. But I think you are reading the info I posted up incorrectly.... DO NOT GET a 34740 crankshaft. Your flywheel parts WILL NOT fit that crankshaft. The 33677/33677a numbers I supplied earlier in the thread are the standard length 3/4" output bushing crank that your engine would use.
These are examples of the difference between the 1972-1980 (left) and 1980-1985 (right) tapers.
If I went with smaller crank would I need smaller bearing & seal for the cover? I'm thinking so. I'm in the process of reading all the HS50 mod
Biff, you would only need to change the cover IF you had them machine the crank down to Ball bearing sidecover specs. Bushing supported cranks were rougly 1" bushing, no matter the output size/style, Ball bearing cranks were rougly 3/4" at the bearing so the output end on them can only ever be 3/4" or smaller diameter. The 3/4 output bushing engines are just like owend said he had his cut down from the factory. Makes sense I hope???
Not the best shots, but all I have posted up in the photo section for reference These are bushing cranks from HS series engines:
Here is how the ball bearing supported shafts are cut:
