You guys make it easy to be a n00b. Thank you.
I'm going to try and do this without pictures. My bike has no top end apparently due to about a 10:1 final drive ratio.
There's a 2:1 gear reducer attached to my actual chain drive. It's not a jackshaft. Can I change the rear gear on the reducer and take the cheap way out? It's a 10/20 arrangement, with 10 teeth on the motor and 20 at the rear. I think swapping to a 14 tooth on the rear would do just fine numerically and be very cheap. 18.5in tires do change things a bit. The rear gear on that reducer is the easiest to reach and change.
Thoughts?
Thoughts?
