I have a Baja Warrior with a 196 clone. I was just going to repair the engine and slam it in the frame of this bike, but with how easy and cheap it is I somehow ended up with a shaved head, .036 jet(stock emulsion tube), aftermarket air filter, Modified rocker cover with PCV valve and breather. These things are addictive. Now I went to order a chock switch and ended up getting a .022 side covergasket, 10.8 springs(green), BSP-2 cam(couldn't pass for the price). I still have stock exhaust, but I'm thinking I'm going to weld up a pipe to fit the frame. I have an old style hot dog muffler. Found in the corner of the garage.
As far as the flywheel and Conn rod goes it is still stock. So with that being said I'm going to keep the governor. However I don't like the idea or having the internals there. So I'm in debate weather to take it out and have a throttle stop or just keep the governor in till I'm willing to go to connecting rod and flywheel.
Do they make a light weight flywheel with the magnets for the generator? I would like to keep the charging system. Turning high RPM is last on my list, its not important. I'll be happy with 4k.
Criticising welcomed, I have thick skin.
