I have a yellow clone and I was wondering if I could put a charging coil on it to run lights? What kind of coil is best and does it replace the factory coil or is it an add on? Any help greatly appreciated
I do think you can but you need the clone lighting flywheel and coil to do so. Look at Baja motorsports web site they have them for the Big warrior style bikes under the parts section.
What about Honda could I use a gx200 flywheel and coil? Also I was reading that when not running a stock engine a billet flywheel should be used. Is there a way to have a charging system with a billet flywheel?
