clutch cover
New Member
would anyone happen to know of a clutch cover that would fit over a bully 2 clutch, that would fit onto a predator 212cc engine ?
I think there is probably quite a few covers the would fit over a bully clutch....you might have to space it outwards some. As far as bolting up to the Predator they are the same bolt pattern as a Briggs or a Tec. engine.
New Member
well the last two i bought wouldn't fit because the bully clutch is larger than other clutches, but ill continue looking
I take old real estate signs and bend em in my vise with angle iron in the jaws to make my covers and can make em as wide or narrow as I like, a piece of angle iron for a bracket with drilled and tapped holes to mount them on. You will be hard pressed to find an aftermarket cover that will span the distance but there could be one out there for you.
