Coleman CT200u
#21
looking good.
Hey Kacz, your CT200U looks awesome! :thumbsup: I just got one from BJ's wholesale. Can you list some details of what you've done so far? A " how to" with pics would be awesome.
I wanted to try to get a flywheel with coils to generate some electric power for a head light, wonder if the one from the Baja MB200 could be fitted?
Bringing this back, has anyone tried installing a Baja front suspension on the Coleman?
I want to install a different handle bar but I would need a triple tree to do so. Anyone change the handle bars yet?
#25
Not a bad thought TAA. Those Baja forks might work, that idea is worth checking further into.
I'd been considering just taking mine into a local weld shop and have them add a few inches height and width to the stock bars. The grips are always hitting my knees in tight turns. There is some slack in all the factory cables but if i go to where i want them i'll probably have to get longer ones. I've gone all year with no mods done to my bike but figure this winter may be a good time to get started.
#26
if you guys come up with something, I'd like to hear it. I've been wanting to put some type of shock absorber front fork suspension on my CT200U as well.
#27
I tried to locate the Baja front fork but they have been recalled. Parts are not available for the forks. I might consider cutting off the handles after the mount. Installing risers and a new style bar. I will have to wait till Monday to see what you mean about hitting the knees. From the looks of it, the bars look high. I don't like the look of the ape bars and these remind me of them. I am going for the cafe racer look, straight across bars.
#28
I was looking into making a triple tree design with shocks for this. The only problem I foresee is the wheels/tire is Wide. If I use a motorcycle triple tree it might look oversized. The pocket bikes triple tree is narrow for narrow tire. Any thoughts or ideas?
#35
yes, I've added the Tav2 30 Torque converter. my post is in the CT200u Group section on how I did it. I had to cut that lower support off (chain guard support bar). I've seen pictures where other members welded it back in, in a different position. I left mine off, and no difference in performance/stability yet. I've bought a 1" think aluminum plate to raise the motor up, and ground out the unused oil fill in the back of the motor.
The Comet TAV fit right in after those mods. I was even able to reuse the chain that came with the CT200u.
Motor is still stock ATM. but it went from about 18MPH to 38MPH.
Soooo glad I spent the time to install it. I'm much happier with it since I added the TAV.
I do take it off road a little, and it's got plenty of pulling power to take my 225 lb arse up hills... lol
I saw someone on you tube post a video with that support cut. Was that you ?
I see that's the only way because that pully need 3" space from the shaft over.
#38
I've never done any video's or posted any pics.
Yes, there is actually a CT200U group. Not very active with only 2 members though...:smile:
#39
Where is that, I wanna join. Send a link... So today I installed the OldMiniBikes air filter but the bike hesitates now which it never did. It does clear up but it does that when you first give gas. Also I noticed my studs in the carb were too long. So when installing the OldMiniBikes nuts, the Allen key would hit the stud when snug. But it was still loose, so I found some rubber washers and dropped them in and then installed the nuts. Now I was able to tighten the nuts without the Allen key hitting the studs.
Has anyone removed the flywheel yet? I am curious to know if there is a hole for a starter and holes for the charging coil. Since I can't find the front fork I am considering the electric start. Anyone????
