Hello all. I have what I believe to be a Comet TC88 torque converter set-up on my K&S Hornet. I am currently restoring this minibike and would like it to get it running as good as possible. The hub on the crankshaft was very hard to pull off and I had to try several different methods before getting it off. It finally took a splitter in between the hub and brass ring with a 2 jaw puller to get the thing off. Prior to that, I tried to clamp the back plate and ended up slightly warping it. My question is, "since it is slightly warped, and I do mean slightly, is it toast? If it is toast, what are my options, will a Comet 20 back plate work?
Should I just bite the bullet and buy a new Comet 20?
Sorry for so many questions.
Thanks for any help!
