2 bikes. Both currently stage 1 and properly jetted. Same torque convertors (China blackhorse from amazon)
Megamoto 212 pro with a 196 hisun 10/53gearing
Coleman ct200u with a non hemi predator 10/50 gearing
The Coleman flat out rips. It wheelies on demand, if you try to hold the bike back it will stand up. I have climbed some super impressive hills on the trails with it.
Megamoto feels super sluggish. You can physically hold the bike back with your feet on the ground. I can't even make the front end light let alone flip the bike over like I can the coleman.
In a short Drag race the coleman out accelerates it no problem, by a couple lengths.
Using the gearing calculator I am physically running the full potential of the rpm. 3600 rpm at xxx speed matches a gearing calculator.
What's the problem?
I switched torque convertors between the two bikes. No change.
The obvious one of the predator vs clone.
The megamoto is a heavier bike.
I am pretty disappointed in my build so far....! I was super excited to score this frame and start a build on it.
I ordered a yellow spring and a 9 tooth sprocket to drop the gearing down hoping it will give me that low end pull that I want.
I dont care about going 40mph. I ride at less than 25mph 90% of the time of the trails.
What's the problem?
