No, when you bore an hs 40 block to accept an hs50 piston the little hex screw bolt hole that holds the tin around the fins on the cylinder will be exposed in the bore; ask me how I know. Also the cranks are completely different, not even remotely interchangeable.
Wiseco PN# 2001P8 is an .80 over for the HS40 if i'm not mistaken that's 2mm over stock. There used to be on ebay but, it wasn't listed as such. it was just listed as Tecumseh piston.
EDIT: found the guy's store, best i could find is this, it's number off. i could have swore he had in the same color box but, with the EXACT same part number (2001P8), maybe he finally sold it.
EDIT: There is another part number on the box "061026" yup might ask that eBay seller if that number is on the other side of the box. at least on my box that is.
Haaa, yeah, I get around. It's for a buddy's 1970 Rupp Roadster.
I'm doing a 10hp Tec for Pop's snowblower. The 7 broke the rod. I cleaned up the ports, upped the squeeze a tad. I'll pulley it up, govern it down, for long life and ability to really chuck the drifts up north where he is.
My Kohler K341 has a long rod, Chevy piston and valves. I'm not well. lol
