I have had this for many years and originally put a Briggs 3.5 HP engine in it. My son rode it over 15 years ago. Now retired I am doing a better job of restoration.
It will be powered by a Harbor Freight 6.5 HP engine. I think they call it the Predator. The wheels are just some 6 inch split rims with a 4.50x3.5x6 tires. These are 4 ply purchased from OldMiniBikes. The original bike had a rear drum brake. I am using the clutch break. Once I get this completely mocked up and get my drive train ironed out it will be disassembled and powder coated black. I have the original chain guard and working on cleaning, prime and painting it. Since the engine is blue I plan on painting it the same color. The bike also came with rounded front and rear fenders which I am searching for something that can look like the ones that came on it. The fenders will also be blue as is the engine and chain guard.
I am going with the heavier drive train that uses a #40 or #41 chain with steel sprockets.
Take a close look at the wheel. This time I am using spacers with set screws to hold the wheel in place and prevent over compressing when tightening up the outer nuts. The last time I built this I did not do that and it screwed up the bearings. I plan on doing this on the rear as well.
Normally it does not come with a kick stand and this time I welded one on. This is a must have for parking it.
That is about all I can think of at this time. If you have any questions, please ask.
