I just installed the Power Up Kit on my Dirt Bug 212cc Predator ,which included the under the seat RLV header, K&N Pleated air filter, racing spark plug and jet and had a question about the tubes that are left.
Once I removed the stock air filter what do you do with the tube that on the right side of valve cover? You also remove the fuel line breather tube, but I would assume you could plug this or run a longer line down? The videos online just leave the tube after you removed the old air filter and don’t address it. I ride on dirt and gravel trails and would think that I could get dirt or water in the valve cover it is just left alone. I thought about routing it thru the air filter with some longer tube but was not sure if the line coming off the valve cover is a breather or vacuum.
