I googled 'V-Plex torque converter' looking for factory info or literature...the best info found was your (delray's) original copies posted at minidoodle.com...
I was going to link to the page, but this was info donated to minidoodle, and posted to help others free of cost, so I exported it here in the hope that it will continue to exist and be easier to find for anyone needing it...
I'm aware that some people consider anything donated and posted to be the protected property of the site it appears on...I just don't believe that to be truly correct when the original intent is to share the item freely with others at no cost...
I've noticed that older-model drive components usually had two set screws...one positioned over the keyway, and another, usually 90 degrees away, positioned to screw against the mounting shaft...
The trend on newer components seems to eliminate the second set screw...
I can't find any factory info on removing the unit, so if it were mine, I'd look for two set screws before cleaning the shaft, then using a press to remove the driven sheave...
