I have been hand sharpening drill bits on my belt sander for years and years. I have been pretty good at it for a long time but that is just it. I am only pretty good... It is a hit or miss deal sometimes. Sometimes I can sharpen one and it will cut like a hot knife through butter. Most of the time I can sharpen one that will drill a nice clean hole. And then there are those that would not drill a hole in a 2 X 4.....
I have a little Drill Doctor that was good right up until the bit holder failed. I have been looking at the bigger Drill Doctor but am just a little skeptical about them.
Anybody have suggestions and recommendations for what they use. I have hundreds of drill bits and would like to tune them up as I use them.
Sometimes when I sharpen a bit it cuts real good but you can tell it is only cutting on one flute and the other is just skating along. I don't drill a hole with out using lubricant. I use Rapid Tape and have had outstanding results with it.
I have been looking at sharpener choices and I see the old style fixture that you use with a bench grinder. I have never used one of those. Any input about them, good or bad?
Share your thoughts and experiences.
Thanks,
Doug
Thanks,
Doug
