hey guys...I have my HS35 TEC engine mounted to my MTD frame now, and I have a Comet Tav 30 mounted to the engine...now...I want to take off the factory jackshaft..and install an extended one. TO remove the factory shaft..do I just remove the retaining ring on the back side...or remove the nut from the outside? I would assume it was the retainer ring, and then pull the driven pulley and shaft out..but I wanted to check to be sure.
Dan
Dan
