I have a 3HP Briggs flatttie. I had just cleaned the carb and cleaned and re-gapped the plug. So I fire it up, vroom vroom... sounds and runs 100% better. (It had sat for a long time, wouldn't run at all). It suddenly makes a nasty sound, one that I am pretty sure is the starter clutch binding, and it dies. Sure enough the starter coil is messed up, so I fix it, slap it back on, make sure the engine turns over nice. Go to fire it up, and the timing is obviously off. So, I pull the fly wheel, and sure enough the key is shredded.
Can the starter clutch binding really shred the flywheel key? Or did I do some internal damage? It seems fine, other than the flywheel key, and the starter spring was tweaked.
Thoughts?
Thoughts?
