I want to run a Dellorto UA19s on my next build (HS50), I sort of want to keep the steel engine mounted tank on the front of the engine though, problem with that though is the dell is going to sit higher than the bottom of the tank.
So I either have to run a pump, make an intake that comes down low, or loose the tank.
never ran one of the fuel pumps on anything, dunno if its a pain to do or work with. Not sure how well the dell would do with much pressure on it :shrug:
I should have the room to run the intake down low and off to the right under the exhaust on this bike, but I dont know if that will be ideal.
